- msmith1199Explorer II
ADAD437 wrote:
STBRetired wrote:
If you have an Automatic Transfer Switch, just follow your shore cord and it will connect into the ATS. Some MHs don't have transfer switches and have a receptacle in the compartment where the shore cord is stored that you must plug the cord into to use generator power.
X2. on my 05 gb pursuit that is where it is.
x3 on my National Tropical. Shore power cord is attached to it. As somebody already mentioned check the breakers on the generator. Last time I had no power from the generator that was the problem. - ADAD437Explorer
X2. on my 05 gb pursuit that is where it is. - 2chiefsRusExplorerit might not be the ATS at all. Did you check the breakers located on the generator itself?
- STBRetiredExplorerIf you have an Automatic Transfer Switch, just follow your shore cord and it will connect into the ATS. Some MHs don't have transfer switches and have a receptacle in the compartment where the shore cord is stored that you must plug the cord into to use generator power.
- lawrosaExplorerswitch is in the converter... Post make and model of the label in your electrical panel and we can help
- 1492ModeratorMoved from Forum Technical Support
