cac43
Jul 17, 2021Explorer
trying to get stuck tire off
I stopped by a large tire store this am because at an overnight stop I noticed my outside right rear tire was 6 lbs low on pressure. according to my "spit" test the valve core was leaking. I didn't have anything to tighten it. the repair man said that the entire stem had to be replaced
and to do that he had to remove the tire. I reluctantly said ok if he was sure. he took off the lug nuts but the tire was stuck so he couldn't get it off. he proceeded to use a 10 lb sledge with a 4'
handle and began to pound the tire itself as hard as he could. after 20 times the tire was still stuck. so I told him to quit and just tighten the valve core and air it up.
I'm wondering how much damage to the tire and if this was an accepted procedure.
has any one else had this happen? thanks. chuck
