Jim102
Mar 27, 2018Explorer
"Tuner" for a V-10
Buying a new Jayco Precept 29v, has a V-10, now, does anyone have good or bad things to say about a tuner for it? And who you like... This is all new to me. Thanks, Jim
Dale.Traveling wrote:dbbls wrote:
You have to use premium fuel.
Why? Premium or high octane fuel is needed for high compression engines and at 9.2:1 the Ford 6.8L V10 isn't. A very custom tune with a heavily modified fuel injector duration pulse might need it but you'll probably either blow a head gasket or burn a valve pretty quickly changing the much from the original Ford program. Bolt on a turbo, super charger, change out the cam, shave the heads and so on maybe. But an aftermarket tuner specific for an RV application, not likely.
