mike_brezExplorerApr 28, 2019Turbo leakJust discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...Show More
sailor_louExplorerApr 29, 2019As the others have noted, this is not a job for WD40. Use a true penetrating oil like Kroil (the best IMO) or PB Blaster. Good luck and safe travels.Lou05 Travel Supreme Envoy
Related ContentNautilus P1 has leaking connectionsTurboDuramax TurboLippert faucet leaks, replaced with Moen7.3 twin turbo Godzilla
