Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
I would run it, soak it, even heat the nuts when you get home. I would run a file over both surfaces and if the studs come out instead of the nuts, replace with SS all thread.l and SS nuts.
