Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
Hi Mike, I have several "3 legged dogs" for different size drill bits which will keep the drill bit straight if you break off a stud that you can borrow. I have used Kroil oil and gas mixed with transmission fluid in the past with some success. I have better luck using a breaker bar and a 6 point socket that I would tap on with a hammer while applying torque to the breaker bar after soaking the area.
