I removed the top nut yesterday without issue. The bottom two are going to be a different story.
I have everything else besides those tow nuts freed up and should be able to slide turbo out enough past studs to replace gasket.
I have found the gasket on line and the clamp I broke but waiting until everything is apart in case I need something else. Soaked the bottom two studs and nuts this morning will do it a few more times throughout the day.
Someone mentchioned about having the correct tools. The last pic shows everything used so far.
