Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
I was going to get the turbo on the bench to clean t out. I'm sure I got some of the acetone/atf mixture in it from where the gasket was broke not sure how that will effect it. The turbo is a Garrett ar 58. Looks like the gasket kit comes with the o rings.the small gaskets for were the oil lines bolt to turbo and the big gasket from turbo to manifold.
