mike_brezExplorerApr 28, 2019Turbo leakJust discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...Show More
SidecarFlipExplorer IIIMay 01, 2019I see you like my ATF/Acetone mix. It works very well and it's cheap, like me. You are doing fine...
Related ContentNautilus P1 has leaking connectionsTurboDuramax TurboLippert faucet leaks, replaced with Moen7.3 twin turbo Godzilla
