Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I...
from the pics of the engine with individual high pressure fuel lines you have a Detroit 55 Series engine, it is the same engine as a International DT530 engine. they were also used in some fire engine applications, there should be some International numbers on the data tag on the valve cover that a International truck dealer can cross to get parts
