gmctoymanExplorerAug 09, 2013Turn Signal Flasher E450Has anyone here replaced their signal flasher with a louder unit on their E450 (maybe the 350 is the same) ? Can you tell me what it took to do the job ? Where is the flasher located ?
gmctoymanExplorerAug 11, 2013Did the mod JD linked to, worked fine. If I did it again I'd move the buzzer up behind the knee panel.Thank JD.
Related ContentTurn signal/ flasher helpWhere is the turn signal flasherturn signals & flashers quitTurn signal makes no clicking soundTurn signals
