KevinE
Dec 24, 2015Explorer
UPDATE: The harness leading to the turn signal was buried in the foam insulation in the corner. Once I dug through it, I found the connector was loose. Cleaned it up and reconnected it and secured the wire, problem solved. I think after it was on for a little, the ground heated up and started looking for a better ground somewhere. Thanks for the advise!
