donk0501's avatar
donk0501
Turn signal problem
2003 Gulfstream Class A (freightliner chassis). This morning when I checked my turn signals prior to hitting the road I encountered this problem: regardless of whether signaling a left or right turn, both sides of my lights flashed. I double checked to assure the hazard lights switch was in the off position, changed both relays for the hazard lights, replaced the turn signal fuse, all of which failed to solve the problem. Any ideas what to check next other than a possible short in the wiring harness?
  • Yes, I know exactly what is wrong.
    The two lights that are flashing are actually flashing the thin running light filament. Take a wire from the battery negative, and connect it to the side of the bulb. If everything starts working again, it's that ground wire that is not properly connected to ground.
    What happens is like this. The current comes to the base of the thick filament of the bulb, then cannot exit out the side and go back to the negative because that connection is not there. So it then goes backwards through the thin running light filament and over to the other side and through that running light filament, then it goes out the good bulb on the side and to ground.
    The best way to prove this is what is going on is to take the red lens cover off, and look at the bulbs and the filaments inside them. In your case, the current is going through the thick brake/turn filament, then the thin filament on both sides. You will likely see the thick filament barely glowing, but the thin ones are more resistive to current so more voltage drops across them and they glow brighter.
