bullydogs1
Feb 09, 2016Explorer II
Check chassis fuse for turn signals, then check switch itself to make sure it is functioning..last check connector to steering column..if wipers work then most likely it is the fuse...I am not sure if there is a flasher unit like on older vehicles on the fuse box or if that went electronic as well.
38,783 PostsLatest Activity: Sep 24, 2026
