Gasman 2 wrote:
Dana, I believe Freightliner used a diode in the turn signal circuit. Its located in a wiring harness in or under the steering column. This diode has been known to fail. As suggested call Freightliner with vin and get info to chase this down.
I'll second that. I had a '97 Holiday Rambler Endevour which lost the diode. Freightliner was very helpful in solving my problem. The doide is buried in several feet of a large wiring bundle and rather than trying to dissect it out, I opted for simply running another line with a new (actually a couple of paralled diodes) to handle the current. The wiring schematic I got from Freightliner enabled me to find the end points of the wire containing the failed diode.
Dick Lucas, '04 HR Imperial
