Bossandbabe's avatar
Bossandbabe
turn signals on coach
We hooked up this morning and have no turn signals, no brake lights. We tried to check fuses and so did some service guys - no luck. Now parked at a place that checked fuses, some wires, etch. They suspect wiring in steering column. The manager here in Gorham, NH is going to call around tomorrow and try to find us a place that we can get to. Of course we will be driving without turn signals or brake lights. Camping world south of us does not to do Freightliner Chassis work. Anyone got any ideas?
2000 Tiffin Zephyr 42.5 ft.
  • Check out the emergency flasher switch. Might be bad/corroded/broken contacts or a bad switch. Last time I had a brake light problem, cleaning the contacts fixed it for me.
  • On our rig, the side marker lights are dual filament, and flash with the turn signals. And when there's a bad bulb in the marker light, te turn signals don't work. Just a thought . . .
    al
  • Verify that you have power through the chassis battery disconnect to the fuses and relays in the front compartment driver's side. Use a test lamp or meter.
    There should be a main fuse in this area. Check to see what else is not working. Items that could be effected are hot when ignition switch is off.
