dougrainer
Apr 02, 2014Nomad
Most of the flip down TV's are RECESSED into the roof cavity. If you try to install any type flip down without a recessed cavity, you will hit your head on the TV when it is flipped up. The mounts for most of the recessed TV's is located where your front overhead cabinets above the dash mount to the ceiling as there is usually a stud. BUT, the recessed TV's have a Steel brace/stud that is installed to help support the mechanism that folds down. Most motorhomes will NOT have a heavy duty stud, much less a Steel stud to support the mechanism. Doug
38,780 PostsLatest Activity: Nov 24, 2017
