RodallgExplorerSep 27, 2013TV reception?First off, my MH was from my parents and the only time they used the TV was when they had cable at their park. Now I'm trying to get it to work with the Wingard bat wing antenna has me stumped. Tried ...Show More
Old-BiscuitExplorer IIISep 27, 2013The antenna has to be 'aimed' at the tv transponder towers.....signal is directionalAlso do you have a 'digital tv' or an analog tv?If analog you need a digital converter boxOnce antenna is aimed properly you have to set tv up for 'air' or ' antenna' and then do a scan for available channels
