Rodallg
Sep 27, 2013Explorer
TV reception?
First off, my MH was from my parents and the only time they used the TV was when they had cable at their park. Now I'm trying to get it to work with the Wingard bat wing antenna has me stumped. Tried ...
Rodallg wrote:
I have everything that I believe I should have installed.
Installed is the switching box (the one with all the buttons).
Wall plate with 12 vdc to it and the 3 coax connections behind it (2 are hooked up, 1 to the antenna and 1 to what the instructions say to the 2nd tv).
I have 12vdc at the coax end (at the antenna).
The A and B switching box.
The tv is a newer tv (20" LCD).
I have the antenna up and rotated in all directions.
Do you have the TV input set correctly for AIR signal? TV input must be programmed for correct signal input yup are connect to.
I did the channel scan in antenna and cable with no hits.
What am I missing?
