blknomad wrote:
I have read several of these post of people who are downing the use of tow dollies and I'm pretty sure I know what you are doing.
First, tow dollies as are trailer axels are made with a certain amount of caster and toe-in so it will self center after a turn same as a car. If your receiver is not the proper height it won't track straight.
Second, If your straps get loose, you didn't put them on properly. I may have to add a click to the strap ratchet but not often.
Third, How do you hook up your 4 down in the rain? The tow bar pins, the safety cables, the light wire, how long do you have to idle and run through the gears to oil the trans? How often do you stop to do this? Did you pull the fuse? Install brake controller? Must be Magic.
Fourth, I can back my dolly and car just as far as you can your 4 down.
Finally, DW and I can load our car and strap it less than 10min. and unload it in 2min.
If you decide to go with a tow dolly, get a good one It will be cheaper than having nice car butchered to install tow hooks and having to buy a brake controller.
Sorry I had to vent.
I've connected & disconnected in the rain plenty - no biggie....connect/release 2 pins, connect or release 2 chain hooks and plug in or remove the electrical....its 60 seconds TOPS.....Im sorry you're spending 10 minutes in the rain.
I don't need to lube or run thru the gears in my Jeep's to lube the trans periodically....pull the transfer case into Neutral & your done.
Theres no fuse to pull either....and i don't have to leave the key in the ignition to keep the steering wheel unlocked either.
no butchering necessary EITHER - base plates are made to fit, no bumper, frame or body modifications necessary....baseplates BOLT on (thru the frame) using factory bolt holes....its almost like Jeep BUILT the Wrangler (and others) KNOWING they would be towed....oh thats right they DID !
i guess your right....my toad is more magic and much less hassle that i realized....thanks for pointing it out to everyone !
