Can anyone tell me if there are two fuel pumps on a 2001 Minnie Winnie E 450 Super Duty? Motor cranking but no fuel getting to the engine. Not even getting to the fuel filter. Still trying to test wir...
To check the fuel pump on any fuel injected vehicle do this.
Have a friend turn the ignition key but do not start or crank the engine you get under the vehicle, place the palm of the hand on the tank, some tanks have a protective metal shield so make sure it is the tank, have the friend turn the key several times while he counts 3 seconds 1001, 1002, 1003 and then turn key off and repeat several times.
If there is no vibration and no hum, the pump is toast!
