Can anyone tell me if there are two fuel pumps on a 2001 Minnie Winnie E 450 Super Duty? Motor cranking but no fuel getting to the engine. Not even getting to the fuel filter. Still trying to test wir...
Something worth a try - while someone cycles the ignition, give the tank a good whack repeatedly with a 2x4 (ideally right under the fuel pump) and see if it brings the pump to life. The jostling may be just enough to shake a worn motor commutator into position to spin up again.
I had that happen to a Chevy pickup that began showing signs of starting issues. Was out camping one day and it failed to start, no fuel pump noise. That trick brought it to life sufficient to get to the shop.
