jkmac408ExplorerApr 09, 2015two questionsWe have just bought a gas class A and I have a couple of questions. First is about the Tow Haul having never used one I was wondering if you use all the time or just if you are in hills or mountains...Show More
PopsieExplorerApr 10, 2015Some Velcro tape on the bottom of your cushions would probably do the trick.Try the wide tape, and put two on the bottom of each cushion running from front to back.If it doesn't work you can take it off.
Related ContentNewbie power questionDicor Lap Sealant QuestionAnother solar question.Odd QuestionGenerator question
