We have just bought a gas class A and I have a couple of questions. First is about the Tow Haul having never used one I was wondering if you use all the time or just if you are in hills or mountains...
I thought the tow/haul dropped the transmission out of overdrive into the drive 1:1 gear. No shift points are changed. Is this correct??
I had a 1994 Vectra on a Ford F53 chassis. On the end of the gear shift stalk was a button, This button dropped the transmission out of overdrive into drive. Was this the same as tow/haul???
