ugh's avatar
ugh
Typical Towing Capacity for Diesel Class A
What is the typical towing capacity for diesel class A? I am going to look at 2002 Bounder that has 300 HP Cummins engine in it. I know it is more complicated than that as we have to consider another factors like GCWR, tongue weight and other stuff. I just need to know what is the typical towing capacity to determine if it is worth 3 hours drive to check it out. I know typical towing capacity for gas class A is 3500 to 5000 pounds. But, what is typical towing capacity for diesel class A.
Thanks.
  • rv2go wrote:
    I assume that you have confirmed that your 2001 F250 can be towed 4 down.
    From my 2001 Dingy towing guide.
    "Super Duty F-250/350 4x4: Manual transfer case only (not electronic shift-on-the-fly 4x4). 5500 Lbs."
    Yes with drive shaft disconnect.
  • I assume that you have confirmed that your 2001 F250 can be towed 4 down.
  • Corkey05 wrote:
    You might want to rephrase your question ... as asked it's kinda like asking how much water does a water glass hold. Water glasses come in all sizes, but they're all glasses.
    How much do you need?
    My coach is, tongue - 500#, towing - 10,000#
    Great idea. Ideally, I need something that can tow my truck. My truck weights close to 9000 pounds. Its paid off, so I don't want a new car payment because class A cannot tow it. I rather have higher payment on class A that can tow my truck. Make sense? My truck is 2001 F250 Crew Cab short bed.
  • You might want to rephrase your question ... as asked it's kinda like asking how much water does a water glass hold. Water glasses come in all sizes, but they're all glasses.
  • http://fleetwoodrv.com/frvlibrary/docs/2002/2002_bdr_f.pdf
    5000# for that Bounder. Others vary from 5000 plus.
  • I think that according to the specs, the 2002 Bounder diesel has a towing capacity of 5000 pounds with a tongue weight of 500 pounds.
