mpierce wrote:
Running 22.5's on semis and trailers, loaded to legal max over 90% of the time, I would get 300,000 on the tires, as long as nothing damaged them, and I kept them balanced and aligned. I balanced them, then put BalanceMasters on, and would align 1-2 times a year. Using Crossfires on the duals to keep the pressure exactly the same in both tires helped a lot. 2# pressure difference in the tires on a pair of duallys means one tire is going farther than the other, thus causing the rubber to scrub off.
That is serious mileage. What time frame would that be? I think I would be happy to make it to half that on mine.
