Hello all ,has anyone changed ujoints on a Roadmaster RR4R chassis? If so, how difficult? (More specific would be driveshaft removal as I will take to driveshaft shop for joint replacement. ) ...
The problem with replacing them yourself is they are really big - too big for the rental tool you get most places. You can pound them in and out but that's risky. (Don't even think of pounding on an aluminum DL) The last time I did it I just took it to a drive line place and had them supply the joint and press it in. It cost me about $17 over doing it myself and buying the joint. And they will get it centered perfectly.
