wolfe10 wrote:
Interesting, as Caterpillar and Cummins both in writing say all their engines are OK on ULSD with no additives.
And if ULSD is such a serious problem, one would think that the OTR truck would be stopped all along the side of the highway with issues, as they do a LOT more miles with the same engines that we use.
^^Exactly. We have 45 OTR trucks here at work and do not run additives other than the winter blend to help with gelling, which I might add is a little more problematic with the ULSD vs. the LSD preveously used. The reason most of the leaks showed up in 2007/2008 when they switched over the ULSD is due to the lack of aromatics. When they strip the sulphur from the fuel the aromatics comes out with it. The new fuel systems take this into account. The seals mainly affected were those made of nitrile rubber (Buna N). Aged seals which did not adapt well to this change seemed to fail sooner.
Another "theory" on the leaking seals is that the new ULDS fuel is more susceptible to oxidation which would attack the seals and cause them to age prematurely. This is merely a theory though that was presented at a fuel seminar that I went to a few years back. Not really proven like the reduction in aromatics issue.
In 2007 when we first switched over to ULSD our lift pump on our Cummins ISL started to leak and I merely replaced it and went on our way.
My theory now is put as much fuel through it as I can by keeping the tires rolling down the road.:)
Mike.
