dallaswinn's avatar
dallaswinn
Unclog Drain??
Hello! I have a 1996 Fourwinds and the bathtub drain is clogged. What is safe to use to unclog it?
  • A good idea to help prevent clogs is to occasionally fill your sink and tub full to the top then pull the plug which allows for a good whoosh of water clearing small debris before the build up.
  • I also carry one of those little plastic snakes with the barbs. Works great on drains and traps. Also carry a little 12' snake. Nothing it won't reach from either direction.
  • I think it is called Zip It at Meinards. It cost about $3 for a two pack.
    Mike Leslie
  • Go to Home Depot or Lowes. We've found the best thing to use is a little strip of white plastic about 18 - 20" long with barbs on the sides. You push it down the drain. When you pull it out, the barbs grab onto the hair ball and pull it out of the drain. It's cheap, it works and it's easy to store until needed again.
    Bill
