subtroll wrote:
I removed the cover but no description inside or out.
If Freightliner, you need to contac Freightliner. Doug- subtrollExplorerI removed the cover but no description inside or out.
- It is part of the Chassis maker harness and systems. Has nothing to do with the leveling jacks. At one time there was a cover and it should have had what the relay's and fuses were for. Doug
- MrWizardModeratorJacks ?
Power down, power retract could require 8 relays - MountainAir05Explorer IISorry , no help here, But you can un plug the red plugs and you will find out fast what they went to if someone does not answer you.
- Executive45Explorer IIIPull one of the fuses and see what doesn't work....Dennis
38,783 PostsLatest Activity: Sep 24, 2026
