spotrot's avatar
spotrot
Unusual tire wear
The outer treads on my steer tires have apparently worn to enough to expose a different rubber compound. I wondered if anyone else has experienced this. The rest of the tread is excellent.
The tires are 245/70R19.5 Bridgestone R250 and according to the charts have been over inflated if anything at 90 psi on a light front end (in spite of the relative heavy wear on the outer treads).
Bridgestone CS had no useful info, just said to take it to Larry, Curly and Mo at my local tire dealer for inspection.
Thanks
John
I'd post a photo if I knew how
  • IMO the tires should be inspected by a reliable tire shop. If they are 22.5 tires, I'd use a shop specializing in truck tires....we can't offer you advice on the safety of those tires without a visual inspection. They may be safe, but they just as well may be dangerous. Don't compromise the safety of yourself, your family and those who share the road with you....Dennis
  • Thanks for the replies
    Camber and toe are good
    When the tires were new, we had to drive westward for 2 days with unrelenting 30 mph cross winds - that took a fair amount off the outer treads. Other than that trial, no suspension issues.
    I just wanted to make sure that what I'm seeing is not a different rubber layer just above the cord. And wanted to know if there was a particular issue with those tires.
  • It sounds more like a front end alignment problems. Have it checked, realigned at a truck shop that specializes in alignment, frame and spring issues.
    If you have the same tires all around the RV, it would be time to have them rotated.
    Ken
  • might be an alignment issue. hit any particularly bad potholes lately?
