Depending on what you have for cabinets, some installations can be very simple. In my coach I just used a piece of plywood to fill the hole where the old TV was. I cut holes for the cables and drilled holes for the mounting bolts. Most newer TV's have STANDARD mounting locations that fit most of the special metal mounting brackets. I just copied those dimensions and drilled holes in the plywood to accommodate the four screws to hold the screen. I got the bolts at Home Depot since they are metric size and this has worked well now for over 40,000 miles. By using the plywood backing to fill the hole and mount the TV I did lose any tilt adjustments that I might have with the metal mounting assembly but my old TV did not move at all. My old TV was very heavy and needed two people to safely remove it.
