j-d
Mar 09, 2016Explorer II
It really seems, and sadly so, that aftermarket fan clutches just don't measure up to OEM a LOT of the time. This really bites when we need a replacement, are willing to spend on OEM and OEM is discontinued. That happened with the older 460 Fords. I count myself blessed that ours lasted the whole time we had that coach.
We had a fan clutch start to clatter in a Dodge van we used to have. 100 miles or so from home after 700 miles on a trip. Called my mechanic buddy and he told me this:
1. Climb under and take it off. What I did, was remove the assembly, fan and clutch, take the fan off the clutch, and put the clutch back on, to hold the water pump pulley in place.
2. I wouldn't need it at highway speeds. This was true. We could even use the A/C on the rest of the way home. But this was a van, not towing, not hills, not summer-hot out.
3. He warned me a failed clutch can pull the bearing out of the water pump, move forward, and tear the back out of the radiator. That was why he wanted me to remove it.
38,782 PostsLatest Activity: Sep 10, 2026
