Mine is back in the shop to fix the front fuel tank filling issue (immediately backing up in the hose and cutting the filler pump off). Again.
I also found out that the grey and black tank sensor wires were crossed, so the black would read "full", when in fact it was the grey water tank that was full. This again was something I told the dealer the last time I had it in and they said it was fine. It wasn't.
And seriously, that leaking house water pump. I don't think I've met one person with one of these Thor Super C's that hasn't had the same problem. I ended up re-routing the water pump down in one of the rear storage compartments. Then ran the lines back up to the fresh water tank. Aside from being much quieter, at least if it leaks again, it will be in one of the storage compartments, and not under the bed.
