Stickboy's avatar
Stickboy
2000 Thor (Four Wind Infinity Motor home
The large driver's side slide-out occasionally creeps out 1/2" to 1" when driving and/or setting in driveway. It usually take about 12 hour, and seems to mostly be the lower edge, and on both front and rear ends of the slide-out equally.
Before I start driving I bring the slide-out completely in and inspect it visually to make sure that it is closed. New to the RV world and any help would be Great.
Also every since this started the slide-out will extend but will not retract without jacking up the outer edge of the slide.
  • That is the correct system, it is a typical Dewalt slide-out system.
    It utilizes a cable and pulley
    system to synchronize the room as it
    travels in and out. It is a non flush floor type.
  • https://www.forestriverforums.com/forums/attachment.php?attachmentid=9296&d=1321739509
    https://www.forestriverforums.com/forums/attachment.php?attachmentid=9295&d=1321739509
    If this does not work send me a email to justforyu@msn.com and will send them that way. One is for the level system and the other one for your slide. Probable just a leaking valve, but would need to know which system you have and it has pictures so easy for you to pick.
