Golden_HVAC
Jul 19, 2014Explorer
Hi,
Weekend Warrior used to have it's dealers install a 50 amp upgrade in the parking lot of the dealership in about 4 hours. It is really simple.
They would pick a basement storage compartment, and put the panel in there, along with a new 30' power cord, and 50 amp main. 30 amp to feed the factory power cord, and a couple of 20 amp circuit breakers to feed various other circuits. I think they fed both of the air conditioners, and a dedicated circuit to the air compressor in the garage area of the toyhaulers.
You can pick up all the stuff at Home Depot. The cord end is the same one as a 50 amp stove plug.
You will need a 125 amp panel with about 10 circuits in it, or more if you want it. A 50 amp main breaker, 3-4 each 20 amp breakers, and a 30 amp to feed the factory cord (that you can cut off back to about 6' to reach the new panel location.)
I would put a stove receptacle on the end of the factory cord (that you cut off) to make a long 30 to 50 amp adapter, for use in campgrounds that only have 30 amp services, or while using the 30 to 15 amp adapter, like in a friend's home.
Write back if you want any additional information.
Fred.
Fred.
38,706 PostsLatest Activity: Feb 01, 2025
