MountainAir05
Nov 15, 2015Explorer II
you can replace it. Just use a dremel tool and a bit and cut around the top and get it out of the way then using the tool slit the inner pipe in a couple place so that you can put a screw drive at the slit and drive it down and it should pop the flange from the outer pipe. That is the way we did it where I worked for years. Put a rag or something down pipe to catch the filings.
try this link,
https://www.youtube.com/watch?v=ey6c4XUNPBc
try this link,
38,769 PostsLatest Activity: Apr 03, 2026
