time_to_go_now
Nov 17, 2015Explorer
mike brez wrote:
Drill a hole at three and nine and use 5/16 brass lags
Every single time I touch plumbing, things blow up and it becomes a much larger ordeal than I bargained for. Call it experience, or whatever, but I now try and use the KISS method when it comes to plumbing repairs.
It looks like you have wood floors under the flange. I would use the brass studs in Mike's pic. Install at 3 o'clock and 9 o'clock and fasten the toilet.
If you really want to use T-bolts, drill and slot the holes in the existing flange. You can hold the top of the bolt with vise grips to keep the bolt from turning while you tighten the nut.
Unless that flange is leaking, I would NOT attempt to replace it. But, that is just me.
Good luck.
38,769 PostsLatest Activity: Apr 03, 2026
