FIRE_UP
Feb 07, 2016Explorer
precioustime wrote:
I have a 2016 Fleetwood Storm 28, Ford V-10 with 4 self levelers. If in storage for no more than a month at a time should I use the levelers to get the 4 tires off the ground? Also how important is it for the tires to not be in contact with the ground, dirt, water for a month or less? I see some people place blocks under each tire to keep it off the ground while in storage. Are tires that delicate to be needing this kind of attention?
Well Sir,
Without being sarcastic here, how many motor homes at full time sights, all over this nation, do you see with rotted tires? NONE! While storing in standing water MAY not be advised, what about all the people back east, in the Midwest, ALASKA and any other place on this planet that has LOTS OF WATER on roadways and streets and driveways, not to mention snow for much of the year that many drive in day in and day out and PARK IN IT, etc? I don't see many tires rotting off any of those cars, trucks, motor homes, large tractor trailers and more because they MAY come in contact with water on their tires.
So, parking your coach, in storage for even considerably longer than your intended month, I'm pretty sure will not do anything to your tires. It won't hurt the jacks, the Jack seals, the Jack system, they hydraulic fluid, NOTHING!
Ours has spent as much as 3-4 months straight, on the jacks while we had other things going and, there's no detrimental damage what so ever.
Scott
38,782 PostsLatest Activity: Sep 10, 2026
