StuartT's avatar
StuartT
HWH Levelors and Slideout Failure
I have a model 325 hydraulic HWH leveling system and HWH slide out in a 2008 Dynamax on a Freightliner M2 chassis. The dash warning light and buzzer came on while traveling and I stopped and checked all the jacks, which were fully retracted.
I killed the buzzer and light by turning the key off at the slide out switch (common power I guess since the jack 'run' light also went out). With the key returned to the on position, the green ‘run’ light illuminates, but pressing any jack down button only results in a solenoid click under the coach near the main control box/motor. The pump motor does not engage. Same thing when you ask the slide to go out, you only hear a solenoid click.
I called HWH and emailed them as well, but they are too busy to respond to their customers. I was told it would be several weeks before I heard back.
Does anyone have any thoughts on where I should start my search for this problem?
