carp65's avatar
carp65
Use of only 30 amp service
We have a newly purchased 2015 Tiffin Allegro Open Road, 37',V-10.
Was wondering if we can operate on only 30 amp service if we are
very careful with our electric useage. Only one A/c at a time,
and don't run the toaster and coffee pot at the same time. Things
like that. We have so many power things--front night shade, awning,
two inside TV's, combo washer and dryer, etc. Appreciate any and
all comments
  • Yes. You can. We have a 36LA. On some 30 amp we can run 2 AC. Under powered CG only 1. We always put HW & fridge on gas, with 30 amp. Our coffee pot is also a thermos carafe so it is off after 5 min and ac is back on.
  • We are on 30 amp instead of 50. With no air or hot water it stays between 117 to 119 volts but with 1 air conditioner on it is between 108 and 111 volts. The hot water tank is on gas. What is the voltage drop with 2 air conditioners running. I would be afraid there would be damage with low voltage with everything running. I'm not a electrician but have been told to try to keep the volts around 110.
  • Good point. If you do not have a Surge suppressor which shuts down at 104, get a PI. I also keep a Kill-A-Watt plugged in to see available volts.
  • I routinely get by with 30amp service even though I have to reduce my 50amp cord with a 30amp adapter. I use my water heater almost all the time and on those cool nights, I'll use my 1500watt space heater on low which only draws 800watts. If we need to use the microwave, we turn off the water heater for awhile - same of a hair dryer. You can easily get by on 30 amps as long as you remember you can't operate more than two large draw appliances at a time. The water heater and the air conditioner - the air conditioner and the microwave - on a cold night, we'll run two heaters on their low 800watt settings and leave the water heater on. If it's really cold, I turn off the water heater and turn one of the heaters on high and that usually keeps us warm and toasty.
    I also use dielectric grease on my plugs to prevent the corrosion that causes increased resistance and heat which turns the plugs black and ruins the sockets. I haven't had any problems with my cords since I started using the dielectric grease - highly recommended!
    all comments
    Not likely all this is going to be on at the same time, so no problem and as long as you're logical about usage. In addition, you can split your rear ac feed with a 20amp plug and outlet and not all that difficult for one with some electrical knowledge.
    When plugged in, all is normal and when unplugged, it can then be plugged into a separate outlet on the pedestal to run the rear ac and leaving 30amps for the rest of the coach, including the front ac.
  • You'll learn to manage as you go along. How you manage depends on the weather. If it's really hot, you'll need to shut everything down to keep the A/C (s) running.
    As stated, you can turn the refer and water heater to gas. You can also turn off your battery charger during the day and save several amps and then turn it back on in the evening.....make sure you leave yourself a note.
    During cold weather camping, you can plug an extension cord into the second outlet at the shore power box, run it into the coach through a window or other opening and power an electric space heater, freeing up the rest of the 30 amps for other uses.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Normally do it half the time in the Summer and 2/3 in the winter. So the answer is yes. Most devices (Air conditioenrs are the exception) you can check the watts.. Round off watts to the nearest 100, that is right close to your AMPS draw for that device.. NOTE: This applies to heaters, and cooking devices)
    Motor driven stuff (Residential Fridge, air compressor) is different.
    NOTE: THIS INCLUDES 12 volt stuff.. Since the converter sucks 120vac
    Add up what you ahve turne don.. long about 27 stop turning things on.
    Air Conditioners, figure 15, no matter what.. You may need to go higher.
    Microwave read the ID tage, a 700 watt MW may well draw 1100 watts (an 11).
    Most kitchen stuff is in the 7 range.
    Hair dryers and space heaters are 12-15
