MetalGator's avatar
Mar 04, 2015
Used Diesel Motorhomes
The wife and are have started looking at used gas Class A motor homes. We are mostly weekend warriors and once or twice a year we take a week long trip somewhere. We use our current RV as a mobile hotel more so than camping. We take our dogs with us when we travel.
Anyway, I have pretty much been set on only looking at gas motor homes since we only put about 2000-3000 miles a year on our current TT. I have been looking at used motor homes in the 3-8 years old range and am starting to notice that the price between gas vs diesel starts to shrink once you start getting 5-8 years old (in some cases anyway). Since this is a big purchase, I want this to last at least 10+ years and want to make sure I purchase exactly what we want/need the first time. I have a friend of mine that has owned multiple gas and diesel motor homes and he is adamant that I should also consider a diesel. He says once I ride in a diesel motor home that I will think it's worth the extra money. Anyway, just curious what others think about a 5-8 year old diesel. Still quite a bit more money than the gas put I could probably stretch the budget a bit. I just always get freaked out about the extra maintenance cost but my friend points out the maintenance windows are longer on diesels so I don't have to do them as often. He is someone who is retired and has traveled across the country twice already in the last year so he is pretty biased towards the diesel!
  • I drive my motorhome in the range that you indicated! That's why I didn't buy a D.P. and stayed with gas. If you still want to get a used D.P. I suggest you browse www.DemartiniRV.com
  • A 5-8 year old coach will be 15-18 years old by the time you plan to get rid of it. At the high end of your expected usage, you will add another 30,000 miles to the existing mileage on whatever coach you buy.
    You will not wear out the engine, whether it is a gas or diesel power plant. Your friend racks up a lot of miles, so for him a diesel MIGHT be the best choice. Many of us have had both diesel and gas coaches. I have never heard of anyone on this forum actually wearing an engine out, whether it is gas or diesel. There have been instances of both engines having catastrophic(very expensive) failures but it was due to some other outside cause rather than the engine being worn out from just racking up the miles.
    Based on your description of the type of trips you plan to take, I would recommend a gas coach and save the extra cash to buy other items. With short trips the larger fuel tank is not very important. With your schedule, you will be spending more time parked at your destination than driving down the highway.
    I would concentrate more on a floor plan that you both like and put the type of engine way way down on my list of things that have any importance in your enjoyment of the RV lifstyle. .
  • We started with a gas class C and the experience is similar. Class A gas have: Spring suspension, shorter fuel range (80 gallon fuel tank vs 100 - 150 on a diesel) , and depending on the manufacturer can be very loud. It depends on how long you travel away from hookups. There is no question that diesel engines last longer.
    Class A gas pros
    Lots of floor plans available
    Lots of inventory
    Lower initial cost
    May have disc brakes
    Class A gas cons
    Poor towing capacity typically no more than 5,000#
    Very loud inside depending on floor and doghouse insulation
    Longer rear overhang (be careful getting fuel)
    More frequent service than diesel
    Service centers are typically only at Ford Truck and motorhome shops that have limited hours of operation
    Harsher ride with spring suspension
    Coach systems are not as integrated
    May need suspension and or steering upgrades depending on the manufacturer.
    Lower fuel economy less than 10 MPG is common 5 - 8 is very common in older units
    Shorter range typically 300 - 500 miles
    Smaller tanks (80 gallon fuel is common, 30 - 80 gallon fresh water, 40 or less gallon grey and black, 10 - 30 gallons of propane)
    Class A diesel pusher benefits
    Quiet ride with no engine noise
    Soft stable ride due to full air suspension
    Typically have well integrated coach systems
    Automatic Generator start (depends on year)
    Panoramic front view
    Very quiet diesel generator
    Excellent turning radius for the size of the coach (a 33’ DP will usually have a 208” wheelbase and a 55 degree wheel cut and can turn around in a standard street)
    Fantastic, fuel capacity (Typically starts at 90 Gallons and goes up to 200 gallons of diesel depending on chassis) gives a realistic range of 1,000 miles on flat ground.
    Excellent water tank capacity – typically starting at 90 gallons and ending up at about 150 gallons
    Well integrated coach systems
    More living space for a given coach size
    Engine exhaust braking system (Pac Brake, variable vane turbo or other great system)
    Usually any truck diesel shop can work on them and many are open 24x7
    Chassis and drivetrain lasts a very long time
    Long service intervals
    Better manufacturer support
    Have tow ratings starting at 5,000# to 50,000#, depending on coach some very inexpensive units have tow ratings of 10,000#
    Large battery banks
    Large residential refrigerator (less common on older units)
    Heated wet bay
    Neatly run wiring
    Weight ratings starting at about 26,000 GVWR up to 55,000# GVWR with a tag axle with GCWR ratings of 30,000 up to 80,000.
    Better fuel economy for similar sized units
    Class A diesel pusher cons
    Limited inventory
    Higher initial cost
    Higher cost per hour for service
    Typically more complex due to better integrated systems
    Limited floor plans (I only found a few floor plans that had bunk beds and a 10,000# tow rating)
  • If you are talking 2K-3K miles per year driving during the next 10 yrs., I would stick with gas. If you are going to retire soon (next couple of years?), then maybe I would consider a diesel.
    In my opinion, a diesel does not like to sit, they like to run! We put about 10,000 a year on ours as we use it once a month. We have already put 6,000 miles on our new one since November (had 3,100 at delivey so we are showing almost 10,000 miles).
    Another thing to keep in mind is an 8 yr. old coach is going to start needing things just from age whether it's a gas or diesel. Tires for sure and some of the windows (if double paned) may have started to fog. Check everything!
    Good luck,
    MM.
