Dale_Traveling
Jun 27, 2016Explorer II
The non-functioning jacks would make a good lift point but a 40' coach is going to be difficult considering the potential weight in the neighborhood of 30k lbs. if not more. My gas coach tops out at 18K lbs. which is a bit easier to work with. Wheel leveling might be a better option.
Before I install a hydraulic system I leveled with two jack stands and a bottle jack all 12 ton. Only needed three (stands and jack) since you want to keep at least one rear firmly planted for the brakes. No bleed down from the jack. Found them at Northern Tool for under $100.
38,783 PostsLatest Activity: Sep 23, 2026
