sillsmack's avatar
sillsmack
V10 Motor Oil
All,
Well, I've done it now.
I brought home a new class A.
Mine is on the FORD F53 chassis.
The oil fill cap & owners manual state it is to use 5W20 motor oil ?
WOW! That sure is thin.
The car makers have been using thinner & thinner oils to get max MPG out of their vehicles.
Well, 5W20 hasn't helped my mpg too much. At 2,100 miles it is making 6.38mpg without my toad.
I worry as the V10 is dragging this lead sled up steep mountain grades towing our 4,500lb jeep wrangler I want it to have Sufficient lubrication.
I live in California and each trip involves big hills & mountains to climb.
So my question is this-->
Could I use a heavier oil to make the V10 last longer ??
My Jeep uses 5W30.
Is any of you out there running a heavier oil ?? What grade ?
What about just an additive like STP ?
ALSO,
I keep my rig at home. When parked beside my garage should I keep the slide in ?
Will it strain the slide mech to keep the room out for months & months & months at a time ??
Curious in Hayward
~Mack
