97 Ford v10 had a p0118 error code, bad coolant temp sensor, replaced. Still get code. Now the Cold Hot gauge doesn't work, stays below the C. My scan gauge is showing a constant temp of 40* after e...
po118 is for the cylinder head temperature sensor located under the intake plenum on the intake side of drivers cylinder head most times the connector brakes scan gauge will read -40 if you go on a site called identifix maybe you can get a free trial and it will tell you what to look for
