97 Ford v10 had a p0118 error code, bad coolant temp sensor, replaced. Still get code. Now the Cold Hot gauge doesn't work, stays below the C. My scan gauge is showing a constant temp of 40* after e...
The sensor in question is located right behind the thermostat on some type of crossover that carries collant to both cylinder banks. I'll see if I can find a new wire harness for the sensor. BUT my real question is about the red high temp light and it's operation in conjunction with the temp gauge. Thanks!
