GizmosMom wrote:
We are looking at TPMS for our 26 foot Ford-450 Class C. Would a TPMS work with these valve systems? Thanks
Yes.
I think you'll find some discussion, perhaps on the suppliers' web pages. A TPMS "cap" isn't much heavier than a metal Air-Through.
I had our original tires balanced after installing BORG valves on the rear and new metal valves on the fronts and spare. From a theory standpoint, we should re-balance. Personally, I don't think the metal valves we use on fronts and spare is enough heavier than a rubber valve with a brass core, to require balancing. The custom rear valves have some heft to them, but we mount them opposite each other. So for front and rear, I believe that if we mark the tire and rim so they go back the way they came off, leave balance weights in place, and match marks on re-mounting, we're OK not balancing just because of the new valves.
