4x4van wrote:
Ozlander wrote:
TNGW1500SE wrote:
roam1 wrote:
is it 12V?
if all else fails, maybe stick a diode in series and drop the voltage. voltage can kill lights
A diode is a just a "one way valve". You'd need to use a resistor to lower the voltage.
Not true.
Actually, it IS true. A resistor is used to lower voltage, while a diode prevents voltage from flowing one way and allows it to flow the other way.
For posters that argue, just post the Definition. Doug
A resistor is a passive two-terminal electrical component that implements electrical resistance as a circuit element. Resistors may be used to reduce current flow, and, at the same time, may act to lower voltage levels within circuits.
