Deano56
Sep 06, 2015Explorer II
Vapor Lock
Today it's 92 degrees out and have had the generator running for 4 hours or so. The generator has stop on us three times, and after a few minutes I could get it started again by playing with the choke...
Deano56 wrote:If it's running out of gas how does it start up again and run fine for a whileenblethen wrote:I will check hoses in morning, i will tell you this I just started up and it was racing pretty high which I didn't think it could with the governor set for 1800, or am I missing something thinking that?
Doubtful on vapor lock. I would start by checking all the rubber hoses for cracks especially around connectors. It could be sucking air causing it to basically run out of fuel.
