vik1's avatar
vik1
Vent cover
Hello.
One question about vent cover.
Is the color is only esthetic or there is a good reason to install a white, smoke or black vent cover?
  • I found out first hand which one is better due to a storm ripping one clean off! :B
    Emergency rv mobile repair call when pouring raining and I had no vent cover. Mobile guy came right out and installed a new one for me and I was good to go.
    'Fast forward 6 months' and I am now in Florida during the hot hot summer, ac roaring trying to keep the coach barely cool.
    I am walking thru my MH which has 3 roof vents I get to the middle of my coach and all I feel is a blast of heat on my head and neck. Look up and I now realize that the replacement vent cover the guy put on does not match my others 2. It was almost clear WHITE.
    That white vent cover did not a dang thing to keep the heat out. While the other 2 which were smoke colored did.
    So yes in my experience the smoke ones are the way to go not ever white. White also lets in a lot of UV's that can discolor your interior also.
    BUT. come summer and winter RV'ing you really HAVE to put vent pillow covers in ANY of the covers because they are all just a plastic lid and do NOT seal when closed. Letting heat and cold in. And letting your ac and heat out. Covering them really drops the temp in summer time.
  • I went with smoked for the vents in the main area and a white one for the bathroom to allow more natural light.
  • I chose the smoke for our trailer. Actually it allows a lot of light in without any glare and is still clear enough to see through. Sort of like sun glasses.
  • I have black ones on ours, let's very little light in. I have enough Windows and really don't like that much light on bright days. Also use vent pillows to insulate when running A/C.
  • The amount of light that is passed in to the trailer. You may want a smoked or black for a bedroom if you wish to reduce the amount of light.
    I have white on all of mine, and by themselves reduce some light. I added 'heavy duty' vent plastics on two that needed to be replaced, which reduced light entry even more. I have foam/foil pillows for the vents to insulate and eliminate any light entry, so the white covers were the best choice for me.
